2001 c5 light problem
stickle
- New User
Hi I've a 2001 c5 lx diesel 110bhp, my dipped beam has gone, l've changed both bulbs and fuses, still no dipped beam. Can anyone help
- x 1240
Re: 2001 c5 light problem
There is a relay that appears to be on the same board as the fuses, it controls both main and dipped beam but has seperate contacts for each which could be faulty. You should be able to find it by putting your fingers on each relay in turn and truning the lights on, you should feel a little bump as it clicks, if it clicks on dipped beam it could be faulty, if it doesn't could be the switch.
