Hi Guys
Old Citroen Owner who went to Ford and made a mistake..Now got a Saxo Forte 1.1 which drives okish..well it drives ok but the gear stick is a bit floopy..is it a common fault or can it be easily corrected..Finds all gears spot on..Just floppy.
Thanks In Advance
Timmy
Hi Again..Long Time No see
- x 8406
Timmy69
Re: Hi Again..Long Time No see
Anyone have any idea's about this problem,cost and how hard it will be to sort ?
Timmy
Timmy
Dommo
- x 20
The three parts labelled 2 and 3 are the gear linkage rods, the ends of which have rubber bushes in them, the rubber bushes wear out over time and the gearstick becomes floppier.
http://www.saxperience.com/forum/showth ... ?p=2003041
On that thread you can see metal replacements, so the rubber bush is gone. I fitted these to my 306 because one of my rubber bushes failed completly and I could only select 3rd and 4th gear - a 35 mile journey home from uni with only those two gears was interesting.
I found these metal linkages were better than my older linkages (before the failed) but they were noisy until I popped some grease into the cups. They have since ovalled quite badly so I can't say I recommend them personally. New OEM replacements would sort you out I'd imagine.
Dommo
- x 20
Looks like new OEM linkages are around £15 each, so £45-50 in total for all three. Or there are all three metal linkages here for £20:
http://www.ebay.co.uk/itm/GEAR-LINKS-RO ... 1257263163
- x 3296
I had item 2 fail on Gracie, and it has a rubber outer bush, with a nylon bush and metal cup within. It was the rubber bush that failed. You can get item 3 from GSF, but part 2 appears to be only available from a dealership. Page 7 of this post;
http://www.frenchcarforum.co.uk/forum/v ... 2&start=90" onclick="window.open(this.href);return false;
Mind you, they are almost certainly not the same as that on a Saxo.
Timmy69
Thank You very much guys..i really do appreciate your help
Timmy.
Ordered and on there way to me
Timmy.
