MOT advisories
xantiagreen
MOT advisories
Unread post by xantiagreen »
Just got the xantia back from garage today after investigating the clutch leak (found to be some sort if anti corrosion coating) and also MOT, following advisories:
N/S and O/S front suspension arm rubber bush deteriorated but not resulting in excessive movement
N/S track rod end ball joint has slight play
N/S and O/S rear upper sub-frame rubber bush deteriorated but not resulting in excessive movement, citroen mechanic said that the MOT centre may have mistook the noise from the Upper engine steady bush as rear sub-frame bushes as he has never changed the bushes on rear sub-frame of a xantia.
Upper engine steady bush is making a jolting movement when accelerating and lifting off.
Am I right in saying that the track rod end is sold separate to the ball joint, only when I look at photo of track rod end it shows a ball joint fitted.
Is there a upper ball joint fitted on the 110 hdi's.
This is advertised as a track rod end for a xantia hdi
This is advertised as ball joint for a xantia hdi
Also citroen mechanic has pointed out that the upper engine steady bush needs replacing, in the photo below it is visible (arrowed) but is behind the part circled, the mount is fitted with three bolts, can I purchase the bush on it's own as a kit (what part am I looking for) or what is the correct name for the mount with the bush in and where can I get it from.
Thanks in advance.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
Miguel
Re: MOT advisories
Unread post by Miguel »
xantiagreen wrote:Just got the xantia back from garage today after investigating the clutch leak (found to be some sort if anti corrosion coating) and also MOT, following advisories:
N/S and O/S rear upper sub-frame rubber bush deteriorated but not resulting in excessive movement, citroen mechanic said that the MOT centre may have mistook the noise from the Upper engine steady bush as rear sub-frame bushes as he has never changed the bushes on rear sub-frame of a xantia./img]
Thanks in advance.
I can't see how the MOT tester can have done that. They do a visual check under the car and look at the subframe bushes...
Track rod ends look like your picture. The balljoint is integral with them. The other balljoints you show are for the ends of the wishbones - a different thing. A decent (not Kwik-fit type places) will often change a track rod end for you if you supply the part and have the tracking done afterwards..
xantiagreen
Re: MOT advisories
Thanks in advance.
The citroen mechanic had a look and found them to be in very good condition also and could not find how the MOT chap placed the rear sub-frame bushes as an advisory. Am I right in thinking if I replace both track rod ends/both drop links/both ball joints/both control arm bushes front axle front and rear that the tracking and road holding should be as near perfect.
Do you know what that part is in between the two arrows in picture above (engine bay photo)
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
x 8444
Re: MOT advisories
xantiagreen wrote: Do you know what that part is in between the two arrows in picture above (engine bay photo)
It's a vibration damper....
citroenxm
Fallen Hero
x 70
Re: MOT advisories
Unread post by citroenxm »
And dealer only too... not expensive iirc .. and its the one further back between your arrows.. :wink:
A very sad...
1994 XM 2.1 d auto
x 1499
Re: MOT advisories
This bit - still available by the looks of it:
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000183946 MOUNTING BRACKT 25.25 GBP 30.30 GBP 30.30 GBP
If it's, er, a bit worn it can look like this :rofl2:
Note that the track rod ends on an HDi 110 are different to most other Xantias, so make sure you get the right ones. Wishbone bushes slightly deteriorated is a common advisory, but often doesn't need acting on - they like to list it when they've got just a but of surface cracking.
citroenxm
Fallen Hero
x 70
Re: MOT advisories
110 hdi uses the larger track rods.. iirc but probably dont they are M16 thread size and not M10..
HDI 90 use the smaller racks and track rods..
A very sad...
1994 XM 2.1 d auto
xantiagreen
Re: MOT advisories
Cheers for info Jim.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
Re: MOT advisories
citroenxm wrote:110 hdi uses the larger track rods.. iirc but probably dont they are M16 thread size and not M10..
Thanks for the heads up citroenxm.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
Re: MOT advisories
RichardW wrote:This bit - still available by the looks of it:
I do hope it's this part does it include the bush inside the mount, (car makes a jolting movement when you foot it from low revs and lift off, if you drive it very carefully everything's fine I initially thought it might have been gearbox mounts or engine mounts). I hope I'm wrong.
1. drop link/link rod (Activa model shown I think)
2. anti roll bar bush
3. front wishbone bush
4. anti roll bar
5. track rod end
6.track arm/wishbone
7.at the bottom end of wishbone is ball joint
Is that correct am I missing anything that isn't visible in the pic (trying to know the correct terminology for the parts on the xantia with pictures.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
x 3298
Re: MOT advisories
Item 1 is DEFINITELY for an Activa, as that is the ram they use.
x 8444
Re: MOT advisories
That Activa ram won't last long. It's missing its gaiter...
