Plastic Membrane
froggy
- (Donor 2026)
- x 4
Plastic Membrane
Hi, my SI Xantia (saloon) is letting water in through the boot! I understand that there is a plastic membrane somewhere within. anybody know where ? could be the reason for the leak ? cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
isisalar
- x 3
Re: Plastic Membrane
Hi Terry
It's in the tailgate, if you remove the inner carpet type cover, held on with quite a few screws you'll see it. Re seal with some sort of mastic.
There was a recent post about this involving using a plastic strip to firmly fix the membrane in place.
Also check the light lenses, the rubber tailgate wiring cover grommets and the sunroof drains.
Cheers
Paul
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
froggy
- (Donor 2026)
- x 4
sorry to sound thick......but where are the sun roof drains ?
Terry
citroenxm
- Fallen Hero
- x 70
Rear sunroof drains go down the c pillar but come out in the top of the rear wheel archs.. I had wet rear carpets on a car which had a blocked drain.. put the car on high make sure she stays up.. leave engine running.. then look up into the rear arch on passenger side you can see the pipe.. poke carefully a thin rod.. watch though if it is blocked you will get a wet arm!
Also rear lamp seals can also let water in too!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Clogzz
- x 40
http://www.frenchcarforum.co.uk/forum/v ... =3&t=21367" onclick="window.open(this.href);return false;
- x 5672
One of the autoshitists blew his out with a garden spray, simple but effective.
VertVega
- x 13
Before answering I had to check the word saloon and got the answer from wikipedia: "Saloon (automobile), a style of car body also known as a sedan"froggy wrote:Hi, my SI Xantia (saloon) is letting water in through the boot! I understand that there is a plastic membrane somewhere within.
Your car does not have a plastic membrane, Only Xantia Estate models have it in the tailgate which can cause such leaks.
So the leak in your car is caused by another source as suggested above. My guess would be the rear lights, hardened plastic around the lamps might be the reason.
froggy
- (Donor 2026)
- x 4
cheers
Terry
