Cruise control
swiveleyedgit
Cruise control
Evening all, looking on ebay for a cruise control stalk to fit to my C5 there's plenty of them listed as fitting various Citroens and Peugeots even though they seem to have different code numbers on the little stickers. Are they all basically the same part? Citroen Service says the correct part number for my car is 6242Z9 but there's only one going on the bay with that number and it's up for 65 quid which is a bit steep, I can get a used one for half that.
Bob
Current Citroen
2004 C5 2.0 Litre HDI VTR Auto
Current Citroen
waynedance
- x 8
Re: Cruise control
Not sure on part numbers but guess it would have to be the right number. Have you got a price from the dealer as might not be that bad.
Volvo S80 D5.........
citroenxm
- Fallen Hero
- x 70
Re: Cruise control
The stalks are all the same fitting, the difference is they are either JUST Cruise control, with on / off , or they also have a speed limiter too!
If you get a stalk with speed limiter its no problem the limiter simply wont work! I put a stalk in with limiter into a 2005 1.6 Design HDi, and when I select limiter it just says limiter not possible, but the cruise setting still works.
You will need Lexia to switch it on, but depending on what engine theres a different procedure to switching it on..
On Mark 1 C5's with 2.0 8v HDi engines you only need to switch it on in the engine ecu- which is what you have. You wont need any ECU codes to do it..!!! However, on S2 cars you need to switch it on in the BSI and the engine ECU, with the BSI you will need the access code too, which I now beleve is a generic code!!
I think S2 procedure is what it is because it shows cruise info in the mileometer under the speedo, where as Mark Ones dont show any info in any display.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
swiveleyedgit
Re: Cruise control
Thanks for that info guys, I have Lexia on my laptop. And as far as I can see there is only the engine ecu that needs to be reset. There's a couple of new stalks on eBay being sold by dealers for about 60 , 65 quid, I would think that's a discounted price, lord knows what the 'proper' price is, I'm too scared to ask!
Bob
Current Citroen
Current Citroen
Miguel
Re: Cruise control
I got a secondhand one off ebay for abotu £30, but call your local dealer and ask. I'm almost sure the price new was only about £50 a couple of years ago.swiveleyedgit wrote:Thanks for that info guys, I have Lexia on my laptop. And as far as I can see there is only the engine ecu that needs to be reset. There's a couple of new stalks on eBay being sold by dealers for about 60 , 65 quid, I would think that's a discounted price, lord knows what the 'proper' price is, I'm too scared to ask!
swiveleyedgit
Re: Cruise control
Got round to fitting the stalk today, secondhand from ebay for 17 squid, I've managed to find the screen in Lexia where you can test the buttons and see them working which they do, but how to actually alter the ecu setting to recognise that the stalk is there is eluding me so far.
Bob
Current Citroen
Current Citroen
jgra1
- (Donor 2021)
- x 36
Re: Cruise control
bob also, you may need a double brake light switch... easy enough to get from a breaker etc.. but if you don't have it, cruise wont work.
cant help re lexia, it was a while ago I fitted mine ;(
citroenxm
- Fallen Hero
- x 70
Re: Cruise control
You do NOT need any extra wiring or switchs putting in, its all there ready as they are!
You need to go into the Engine ECU, and then scroll down to Configure... and I think IIRC in there you will find a list of options that are Absent or present...
Change the Cruise to present and save! you shouldnt need any code or anything!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 5672
Re: Cruise control
Don't you need to tell the injection ECU that it is present too Paul?citroenxm wrote:You do NOT need any extra wiring or switchs putting in, its all there ready as they are!
Have a vague recollection of Chris (citroenmad) posting something to that effect.
citroenxm
- Fallen Hero
- x 70
Re: Cruise control
Engine/Injection ECU, on Mk.1s Steve they are one of the same... good point incase it causes confusion.
Series One C5 (Models to 2005) dont need the BSi changing only the One ECU needs changing, and on Mk.1s theres NO cruise info in either display.
On Series 2 C5 (2005 onwards) the BSi AND Engine ECUs (or injection) both need re configuring. The BSi change promts the Security code when done, but they do show cruise info in the milage window on the speedo, so you actually KNOW what speed you were last dooing when you knock it off.. On Series 1 you need to remember. As knocking either + or - back on takes the car back to the speed last dooing, and if you were dooing 70 and slow to 50 its quicker speeding back up then if you use the accellerator.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
swiveleyedgit
Re: Cruise control
Thanks guys, loads of information there. I think I've scrolled through one of the absent and present menus but I can't remember which ecu it was for, there's hundreds of them by the look of it! Another session with the Lexia beckons (after I've had me dinner)
Bob
Current Citroen
Current Citroen
- x 1490
Re: Cruise control
All you need to know...http://www.frenchcarforum.co.uk/forum/v ... =3&t=45175" onclick="window.open(this.href);return false;
Ah, well, all you needed to know, it seems to have gone walkabout....I'll ask Jim if he can find it
citroenxm
- Fallen Hero
- x 70
Re: Cruise control
No Richard, its there, well, the link works, ive not read through though.. do that now..
**EDIT: I see now, the PDF is missing from server updates no doubt!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1490
Re: Cruise control
Pretty sure you need to go to BSI and injection ECU - and it's called something obvious like RVV in the engine ECU
citroenxm
- Fallen Hero
- x 70
Re: Cruise control
Only on S2 C5s Richard, S1 C5s are more like Xantias, only the Engine ECU needs Cruise activating... My Mk.1 LX was like that, and also was another Mk.1 VTR I also did.
There was NO BSI entry needed.
But I had to on my mothers 1.6 HDi Design! Engine and BSi..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
