I've got to change the strap over, as the old one has done the usual and rusted away.
I've got the new bracket/strap and it looks like a fairly quick straightforward job.
Anything I need to be aware off and does the rubber mount release the old bracket easily or does even the rubber manage to seize up?
C3 exhaust box strap
Road_Hog
Re: C3 exhaust box strap
Well, did it, pretty straight forward.
Old rusty unit needed a bit of wiggling it about with use of flat bladed screwdriver to remove it.
New unit went on fine, but one inch bolt was a bit short, so one and half inch or two inch from local hardware shop to finish it off.
