So my 2003 Citroen C5 threw up the abs fault/ESP not functioning warning last week. After a day or so it started throwing up "Braking fault" on the screen as well, along with the STOP light in the middle of the clocks.
I put the car on lexia and it is bringing up two faults
permament fault : rear RH wheel sensor coherence
permament fault : rear LH wheel sensor coherence
Is this a sign of two faulty ABS sensors??
Permament fault : rear RH/LH sensor coherence
garyfitz123
2003 Citroen C5 estate 2.2 HDi Automatic
- x 1493
Re: Permament fault : rear RH/LH sensor coherence
What does Lexia say the speeds are when the car is stationary - and when it is rolling, compared to the front ones?
garyfitz123
edit : When stationary all sensors read 0kphRichardW wrote:What does Lexia say the speeds are when the car is stationary - and when it is rolling, compared to the front ones?
The front two sensors are reading what looks like correct values, and the rear sensors are constantly reading 0kph
- x 1055
You would have to be really unlucky for 2 sensors to fail at the same time, what's the chances ? Might be worth pulling the plug off the ABS ECU & checking for water/corrosion, same with the rear sensor connectors.
garyfitz123
Was thinking it would be very strange!!wheeler wrote:You would have to be really unlucky for 2 sensors to fail at the same time, what's the chances ? Might be worth pulling the plug off the ABS ECU & checking for water/corrosion, same with the rear sensor connectors.
Now silly question...where can one find the abs ECU??
Sent from my iPhone using Tapatalk
- x 1055
The ABS ecu is in the engine bay on the left hand side of the car kind of behind the under bonnet fuse box, you will see brake pipes going to the unit.
