Run out of diesel
dav3y
Run out of diesel
Unread post by dav3y »
First diesel I have owned and running well for a year or so.
I think the fuel indicator has become sticky, warning light come on and after about 10 miles, lost the oomph. I have been wondering about that gauge !
My question is.. As I have been so stupid to let it run out is there a certain procedure to get fuel back in / bleed. I am aware petrol, you can just chuck in but have never run out in a diesel. Is this a simple process or going to be a complete nightmare and a huge cost?
I had this in mind when it run out so just coasted up to the side of the road and didn't attempt to turn over the engine.
Citroen xantia td sx 2000
citroenxm
Fallen Hero
x 70
Re: Run out of diesel
Unread post by citroenxm »
Car make model . engine fitted.. year ... etc would help us to tell you an answer sir!!
A very sad...
1994 XM 2.1 d auto
dav3y
Silly me
Xantia td sx 1.9 2000
Engine had no power although still ticked over then a few seconds later dash lights popped on as though it stalled, switched off and have not turned over since, thanks
citroenxm
Fallen Hero
x 70
Well assuming it is litterally just run out of fuel and theres nothing mechanically wrong with the engine put fuel in the tank and then under the bonnet theres a primer bulb.. on the left.. you will then need to prime the fuel up to the engine.. then once the primer bulb goes hard spin the engine over a few times so the pump fills up and gets the fuel to the injectors. Dont he afriad to keep her turning for 5 seconds or so at a time. you will need a good battery for it.. but spin it over then prime a bit more so the bulb goes hard again and spin again.
A very sad...
1994 XM 2.1 d auto
dav3y
Phew, thanks for the info didn't really want to be walking a couple of miles with a bag of spanners / unwittingly perform some damage by not doing a specific process. Fingers crossed I'll have her running in a few hours
I'll let you know how I get on. I did buy a fuel filter not long ago with a bunch of service parts so will get that popped in and get the fuel system check over at the same time.
x 8318
Just to add to Paul's excellent advice, have the ignition on so that the stop solenoid on the pump is open when you're pumping the priming bulb. This'll help get the pump full of fuel ready for the first start attempt.
citroenxm
Fallen Hero
x 70
CitroJim wrote:Just to add to Paul's excellent advice, have the ignition on so that the stop solenoid on the pump is open when you're pumping the priming bulb. This'll help get the pump full of fuel ready for the first start attempt.
Doh of course Silly me.. and I knew damm well too... im tired.. its early ish .. thanks jim..
A very sad...
1994 XM 2.1 d auto
dav3y
Thanks guys, will give that a whirl :)
dav3y
:( can see what the primer looks like in the Haynes manual although having trouble locating mine, may have a different model engine?
Tried to attach picture on phone but too big any other know locations? Cheers
x 8318
Yours may well be an HDi in which case I believe they're pretty much self-bleeding due to having an electric lift pump in the tank.
Switch on the ignition and if it is an HDi you should hear a whirr from the tank (that's the pump) for a few moments and then after a bit of cranking it should start normally..
x 5659
A guide to uploading photo's here.
Using Photobucket there is a resize option or you can post a thumbnail that when clicked opens a full size image.
Click on the profile (image) button top right between the search and cart buttons.
Then the "Albums" tab and down on the left is the "Customise Upload Options" link.
640 x 480 is the ideal size for forums, otherwise you invoke horizontal scrolling on many monitors that is an irritation to many.
If you want a larger image to show detail then the thumbnail option, available when selecting a link to post is the better option.
Click the thumbnail above then the + to increase the size and see below the selected image is a highlighted box, click that and copy it then paste the link.
dav3y
All good starts / stops on the button as always.
I tried uploading from a mobile so didn't have the luxury of resizing at the time, will certainly bear that in mind I do have to again though, thanks guys
x 8318
Excellent :-D
harryp
(Donor 2022)
x 73
Unread post by harryp »
Side issue - apologies. Have tried using the Photobucket just, to post a photo. Bit messy, so, how do you get the pic in the blog rather than a link address; and how do you link to "here". Sorry if this is very basic.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 5659
Look at the screenshot above.
Under each image are three link options.
If you want to add a suitably sized image into a post, select and copy the middle one then paste that selection into your post, it automatically assigns image tags.
To post a thumbnail image, select the bottom link (highlighted in the screenshot), copy and paste that in the same way.
