Ive got an early ZX Volcane1991, want to fit later type F.struts which will interchange except for the anti roll bar droplinks. Can I merely use later droplinks on early antiroll bar, or do I have to change antiroll bar too?
Incidentally the idea behind this is to give a greater choice of competition struts and spring and brakes off the S16.
Nick 0151 427 6312/07990 976530
ZX Front struts difference twix early/late
Jon
The only differnce between the early and late front struts (they changed in 92) is that the later struts have a bracket welded on them, to which the later (long type) anti roll bar drop link is attached.
I can't see why you can't fit the later front struts then fit the later, long type anti roll bar droplinks.
