The connectors appear to take 11mm and 14mm union nuts, which are input/output? I'm guessing it won't work correctly the wrong way around?
yes but not tighter the lever should be released until you put load in the back of the car,evilally wrote:So it needs adjusted a little, tighter = more bias towards front? T
