C5 2.2 HDI DPF removeal
ej2095
Unread post by ej2095 »
Hi all
live up near birmingham.
Thinking of getting the DPF removed as fed up of seeing unblock filer message.
Any ideas on the cost or can i DIY?
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
x 1994
Re: C5 2.2 HDI DPF removeal
Unread post by Stickyfinger »
Welcome to the world of MoT's and changing regulations......just wait 1/2 and there will be at least 3 areas of advice.
1. Do NOT do it, it will fail MoT
2 Do NOT do it, clean/replace filter/Eolys and stop killing children and puppies
3 Do it, it may or may not work....but I know a guy who did it and it turned the car into gold/ did it got a warning, took it off....
I am at No 2.....fix the car and stop killing puppies (kids...Yuk...go ahead and mow the little bu66ers down its quicker)
ej2095
lol
Mot not an issue ;-0
might also wang some redex it and have a wang down the motorway with it
x 1994
Err....having a wang on the motorway is surely dangerous ?
I would not use Redex, however I would give it a good push for 20 odd mins. 70mph in 4th seems just about right.
Did you know you can remove them and clean with a jet wash. Are you getting a "Blocked Filter" or "Low Eolys" ?...... or just a "Poss of Blockage" message ?
Also, what car/year/engine is it ?
Do you have a Lexia ?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Has anyone got N0 DPF as a private plate? :twisted:
x 1994
or V6 2DPF
SaabC5
Unread post by SaabC5 »
Take the DPF off, chuck some acidic wheel cleaner in it, allow to sit for half hour and then jet wash all the crap out. Alow to drain/dry for another half hour and re-install. MOT in future will include a check for a working DPF if fitted as OE equipment by the manufacturer.
ej2095
how easy is this to remove and clean?
Would not know where to start.
Last time i did anything mechanical to my car was to replace the alternator.
x 1994
Just as hard as removing an exhaust, a few bolts and brackets with the odd sensor plug.........its that easy/hard
ej2095
any body feel like giving me a hand ;-0
I do ICT/laptop repairs etc in exchange :-0
