Hi Guys I hooked up car to lexia to delete the usual error codes and it told me that my EOLYS tank was empty but I have put it a litre only 7000miles ago with a previous litre 5000 miles before that. It says there is 70g of fluid in the tank? Does that equal 70mls? I'm going to order another litre of fluid but I thought 1 litre was good for 10000 miles? Is 70g the correct reading?
Bandit
EOLYS tank query
Bandit12
- x 12
EOLYS tank query
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
- x 1995
Re: EOLYS tank query
When you refilled it ?, did you reset the counter with the Lexia ??
Bandit12
- x 12
I did try to and think I was successful but it was the first time I used lexia. I remember instructions about opening fuel cap then putting in 10 litres of diesel then restarting etc. Is that correct or was I following the wrong instructions?
I wasn't completely convinced I had done it correctly at the time because it seemed like a lot of things to do in a certain order.
- x 1995
yep...its a bit of a chess game
....only done it once and I wrote out each step on an index card.
As for how much is gram ?....I will have to ask my dealer for you
......naaaa, I do not know, maybe one of the experten will chip in now.
btw....step by step on cards is a great tip I got from an Aircraft engine builder, not only do you memorise each step when writing out the cards you don't miss out one once covered in oil and cold *******ks from lying on the ground for so long
Onlinemyglaren
- x 5672
In terms of water, 1g is equal to 1ml. (at a specific temperature and pressure)
Eolys will not have the same density as water but will be near enough in real world terms.
Bandit12
- x 12
Thanks guys and yes I like the idea of writing it down on a card. I'll do that next weekend when my next litre of EOLYS arrives. Final question. Is there a reason why dpx42 is no longer available and its all this more generic PAT1 fluid? Don't Citroen make DPX anymore?
Thanks again guys much appreciated
