Xsara Automatic Gearbox Issues
gadgetgricey
Unread post by gadgetgricey »
Interested in an Automatic Xsara , but has a slight issue with the gearbox.
According to the seller, its sometimes goes into "safe" mode when setting off from cold. Give it a couple of miles for everything to warm up. Turn the engine off and on again, and all is well? Now showing no warning lights and the gearbox acts as it should until next time it occurs.
Thinking a fluid change would be a start, but just wondered if anyone had any suggestions.
Thanks again
Dave
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
Mandrake
x 695
Re: Xsara Automatic Gearbox Issues
Unread post by Mandrake »
After owning three autos in a row, (one whose gearbox failed) personally I would not touch any auto that has a known fault that is putting it into limp mode.
Otherwise you too might end up with a 140 page long blog... :rofl2:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8412
Mandrake wrote: Otherwise you too might end up with a 140 page long blog... :rofl2:
It's OK, the forum server has plenty of space for database growth :rofl2:
x 1994
Unread post by Stickyfinger »
Smash him down on price to budget for a 2nd hand box and fitting.....then do the flush 1st and cross fingers........take a chance but within budget.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
This fault of the AL4 has been well known for over ten years. It's cheap to fix.
If someone has been too tight or stupid that it's not resolved by now on their car, you've a risk further damage has been caused (as I pointed out on FCF less than two days ago). It's an each-way bet.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Is it a hdi auto then dave? Al4 auto it is unless all the xsara engines got al4 auto boxs.
sounds like an electro valve fault on the valve block. I need to do one an on al4 im using too...
A very sad...
1994 XM 2.1 d auto
gadgetgricey
Cheers both,
How easy is this change, Can it be done in situ?
Yes it is an Hdi.
Dave
citroenxm
Fallen Hero
x 70
This will be the same setup as the c5 mk.1 hdi auto setup then in which case im loving. Be interesting to see how the zsara compares to the c5.
I beleve it can be done in situ as the valve block is on the front of the gearbox behind the raised cover on the front facing the radiator.. ive not done the c5 yet.. its a to do job.. so I cant say how hard or easy..
what ever the top up of fluid MUST NOT BE A DEX FLUID AT ALL...
only an esso Lt type fluid ONLY ... Cant remeber the full name of the fluid.
A very sad...
1994 XM 2.1 d auto
x 8412
citroenxm wrote: only an esso Lt type fluid ONLY ... Cant remeber the full name of the fluid.
LT71141
Also available from your local friendly Cit/Pug dealer under part No. 9736.22 for 2L
