hows it going lads ,
Heres one for you to ponder 2003 110 c5 hdi non dpf starts fine drives fine no faults if it is allowed to warm up but if i get in and drive straight away antipollution fault and limp mode any thoughts
Help
antipollution fault
darbuck
- x 291
Re: antipollution fault
Any thoughts lads
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
- x 1999
Only thought is that it needs to go on a Lexia to find out what is causing it. I don't think many people can help without the info and fault codes etc....there is a map of members with one in the "member" section
darbuck
- x 291
How are you stickyfingers stuck it on my lexia its coming up p0101 I changed airflow ill try again tomorrow weather permitting
Darren
