Citroen C5 tapping noise
Danbuoy
Unread post by Danbuoy »
Hi, I have a 58 C5 2.0 HDI, done just over 36k. Noticed this morning there is what I can only describe as a constant tapping noise which seems to be coming from the engine. Can mainly hear it when stationary. Don't know if it is doing it at high speed, as I can't hear it, but at very low speed (10mph and below) I can just about hear it. Noise sounds a bit like popcorn popping in the microwave, thats how frequent the noises are. Car feels fine to drive, but just at a total loss as to what the noise could be. Seem also to be able to feel it through the clutch pedal.
Current car: Mar 13 to present: 58 Citroen C5 2.0 HDi VTR+
Past cars: Sept 05 - Mar 13: X reg Citroen Xantia 2.0 HDi LX - 160k and still apparently going strong!
Sept 03 - Sept 05: N reg Citroen ZX diesel RIP (died on A50 after an altercation with a Merc)
SwissSPEC
Re: Citroen C5 tapping noise
Unread post by SwissSPEC »
If its a piston sounding noise, then it may be the crank pulley (the one which has the bearings)? Can't remember if i felt anything through the pedal or not though, mine's a mk1 c5 2.0 hdi 110bhp, so your issue may be totally different. Probably best taking the car to an indie to see if a bigger problem is looming on the horizon if you leave it.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
