206 1.4 8v valve clearances
duke
Unread post by duke »
Does anyone have a tip for how to ensure an engine valve is fully closed before checking the clearance? It is impossible to see by eye, and the only other way I can think of is by using a dial test gauge. I have some clicking noises from my 206 engine which I think are a bit more than just the fuel injectors opening and closing.
x 94
Re: 206 1.4 8v valve clearances
Unread post by citronut »
this any use
http://www.peugeot206cc.co.uk/repair-20 ... ef01a3.htm" onclick="window.open(this.href);return false;
Regards, malcolm.
x 8422
citronut wrote:this any use
Looks excellent Malcolm... Verey timely as I still have an 8V TU in the family that needs a fully service soon...
Shame the old 'Rule of 9s' doesn't work on these engines... When no. 8 is fully open adjust No.1 and so on...
x 94
the way in that link you adjust two valve at a time, so its quicker
Regards, malcolm.
duke
Thanks Malcolm, I shall give this method a try.
