Help with my quad bike starting issue.
waynedance
x 8
Unread post by waynedance »
Ok not a Citroen but need help here.
Quad will not start, on pressing the button the starter was sorting of doing a turn stopping like it jammed then another turn. fitted a new battery, checked the starter switch and got 13.6 volts going in and only 2.3 going out with the switch making a clicking noise while trying to start. If I remove the starter motor and hold it my hand the motor spins with the correct 13.6 volts coming from the starter switch.
Fitted back on to bike and back to the clicking noise and only 2.3 volts going to starter from the starter switch.
Any ideas folks, new starter is £150....... :(
Volvo S80 D5.........
x 8446
Re: Help with my quad bike starting issue.
Is the engine itself spinning freely? It's not seized or partially seized is it?
The may also be a problem with the starter clutch. I assume it'll be a motor-cycle type sprag clutch...
waynedance
x 8
Engine fine as starts on the back up pull start.
dnsey
x 19
Unread post by dnsey »
Sounds as though the switch is high-resistance.
Can you bypass it as a test?
waynedance
x 8
Ran a wire direct to starter and nothing. Dropped of the starter to man in a shed who repairs alts and starters, just waiting to here from him.
