What to do with some very old diesel?
Richard_C
(Donor 2026)
x 234
Unread post by Richard_C »
Having a garage clear out and found a Jerry can (proper steel one) with 4 gallons of diesel in it. I recall when I had to travel a lot for work buying it during some kind of threatened strike or shortage. Must be well over 12 years ago.
I think I read somewhere that old diesel can do nasty things to modern engines, so reluctant to use it in the C5 III or even the C3 hdi. Maybe the synergie XUD but still don't want to risk filter blockages etc. I don't think its the same stuff as heating oil or I could add it to my domestic heating oil tank. Mix it with garden leaves, burn and create a privacy smoke screen around the house? Best not perhaps .... Take to local tip where they have a waste engine oil tank?
Any thoughts on what to do with it?
Richard_C
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It'll go OK in an older tractor, just filter it on the way in. Or offer to the biodiesel crowd.
x 8415
Re: What to do with some very old diesel?
Old diesel goes rancid.. Smell it. If it smells like diesel should I'd be happy to use it in a XUD well diluted with fresh diesel.
I'd be wary of using it in a very modern diesel though however good it smells or looks.
If it smells disagreeably like turpentine then it's gone off and I'd dump it.
Also look at a small sample in a glass jar. If it looks clear with a faint bluish or greenish tinge it's OK but if it's gone a bit brown then again it's off and best dumped in the tip's waste oil tank...
Richard_C
(Donor 2026)
x 234
Thanks, I didn't realise it went off in that way. I will do a smell test and jar test but I will wait until I'm not wearing my best going to work clothes.
Historical note - I also came across a little metal can of Citroen "anti-figeant". In my early diesel days (one of the first BX diesels) the UK wasn't well set up for passenger car diesels - you often had to fill up on the truck part of the garage. I think diesel had fewer additives then and waxing was a problem in very cold weather hence a variety of diy cures. I used to throw some in the tank if I was off to Glencoe in January for primeval ski trips.
Richard_C
x 8415
I've an old can of that stuff Richard, I keep it as a historical curio..
I picked it up at a rally a while back...
dnsey
x 19
Unread post by dnsey »
Use the old diesel as penetrating oil - you have a lifetime's supply there!
x 1995
Unread post by Stickyfinger »
in a TRACTOR !
or in your Rayburn so you can heat the West Wing of the mansion:)
Lasse
Unread post by Lasse »
I would pour it into the heating oil tank. Kero has added colour to prevent tax evasion by people who use it in their Diesel cars. If you add to your 1000l+ oil tank it will be well diluted. Easier than to get properly rid of it at the recycling centre.
'73 DS 23 pallas, '87 CX25TRD2 long, '11 C5 HDi 165 Tourer exclusive
KP
x 27
Unread post by KP »
If you were near me or on my travels if happily take it off your hands as I have a few tubs of engine oil and diesel from doing services lately that I mix in a few litters per tank with the XM veg oil to no real I'll effects. There is more smoke when I go over about 6litres per tank but at most I only do 3litres which isn't great as the stock level is slowly building up again lol
