C3 HDi Sensodrive fault
mark230678
Anyone able to help.
My mums car
She was driving down the road and suddenly lost all drive.
No previous issues.
Car displays a dash where the gear symbol should be and will not change.
Have tried resetting with no joy.
Awaiting a fault scan as well at present.
Battery is flashing and eco mode as well. Reads @ 12.7 volts
No noises, clunks bangs when she was driving just seemed as though straight into neutral.
ANy ideas
My mums car
No previous issues.
ANy ideas
- x 1489
Re: C3 HDi Sensodrive fault
Several recent threads about this sort of issue. Lexia may not be that helpful by all accounts. Lighty carries a stock of 2nd hand spares, and just changes the bits till he finds the faulty one
Good news is that is unlikely to be the box, bad news is that it might not be that much cheaper
Mandrake
- x 695
If battery and Eco are flashing could it be a failing battery ? That would be the first thing I'd check before worrying about more expensive possibilities...
Under what conditions was the 12.7 volt reading taken ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
mark230678
12.7 when battery was taken off the car pror to charging
Mandrake
- x 695
That sounds ok for standing terminal voltage, however open circuit terminal voltage on its own doesn't prove whether the battery is good or bad when under load unfortunately.mark230678 wrote:12.7 when battery was taken off the car pror to charging
Unless you have a fancy tester substitution is the only way to be sure.
Simon
1978 CX 2400
1978 CX 2400
daviemck2006
- x 485
These sensodrive boxes are the most awful things imaginable. Does the engine start? Is it stuck in gear? My c2 was stuck in gear so would not start. Citroen changed the gearbox ECU at a cost of over a grand. If it is elderly now I would seriously consider either scrapping it or selling as spares/repairs as it is for next to nothing. Sorry I can't give you better news.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
mark230678
Battery has been charged overnight and battery symbol still flashes.
Dont think its stuck in gear, as it revved freely when it failed.
Won't start now and it rolls freely.
Its an 04 plate, but no issues previous to this.
Mandrake
- x 695
Sounds like you need to get it on a Lexia to have some idea of what's going on...
Simon
1978 CX 2400
1978 CX 2400
daviemck2006
- x 485
Have a look on c2 owners. Com there are a multitude of threads on there about the sensodrive boxes. I would expect the c2 and c3 to be identical in the sensodrive department.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
mark230678
Sorted.....
2 x Bad Earths and a maxi fuse on top of the box
addo
- Sara Watson's Stalker
- x 95
daviemck2006
- x 485
Thats a result. It makes me wonder as it was basically the same fault as mine if I was ripped off, and charged over a grand for a fuse! I shall never know, and cant really dwell on itmark230678 wrote:Sorted.....
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
Mandrake
- x 695
My gut feeling was it was an electrical problem, glad to see I was right, given the alternatives!
Out of interest how did you track down the location of the bad earth's ?
Simon
1978 CX 2400
1978 CX 2400
demag
- x 102
What is the mileage? They generally don't get too high before they start playing up. That is why you see so many low mileage "bargains" for sale.
Dave
charentejohn
Hi, just reviving this a bit.
I have had exactly the same problem, word for word. Garage has looked at the car and said no bad connections but didn't mention the Maxi Fuse.
Is the Maxi Fuse actually on the gearbox and if so where ? Good to know so I can explain what they should be checking.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
