removing the rear sphere mounts
gxantia
Unread post by gxantia »
Changing radius arm bearing, retaining pin broken, gaitor off, not enough room to remove rod. Need to know how to move rear suspension mount out of way.
x 1499
Re: removing the rear sphere mounts
It will come out... you might need to remove the sphere to allow you to push the piston right back in, and the R-clip that holds the suspension unit in place to allow it to slop about a bit. Probably worth unclipping the feed pipe too, so you don't wreck it. It does require a lot of wriggling to get the arm in the right position to allow the rod to come out.
