Wishbone
froggy
(Donor 2026)
x 4
Wishbone
Unread post by froggy »
Hi, my S1 Xantia, I need to replace the front bush on the wishbone. Is it a case of ......."Brute force and ignorance", to knock out the old bush ( hammer) or is there a more gentle way ? it is very tight. many thanks in advance Terry. p.s. what is the torq setting for....wishbone to swivel joint ? (hub) . 8-[
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 3306
Re: Wishbone
I cannot offer advise on replacing the bush, but according to the Haynes BoL the three bolts that hold the wishbone in place have a torque of 85NM, and onto the swivel with a torque of 45NM
x 8365
Re: Wishbone
Hi Terry,
Replacing the front bush in a wishbone is not quite as straightforward as doing the rearward 'P' bush.
The old bush requires removing and this takes some effort. It must be done carefully to avoid cracking the wishbone 'eye' it is mounted in. I know as I have.
The bush is in there very tightly and to get the new one in you need a piece of large diameter threaded rod and a pair of suitably sized mandrels. Trying to squeeze them in using a large vice and sockets may work but it's not the most perfect way to do the job. Team WFA find the threaded rod approach works best.
To extract the old bush we find the best method is to extract the inner core and then very carefully hacksaw a cut in the outer shell to induce a weakness that can then be exploited with a hammer and punch to drive the old outer shell out of the eye.
I say again, be so careful not to crack or otherwise damage the eye as that'll write off the whole wishbone...
froggy
(Donor 2026)
x 4
Re: Wishbone
cheers Jim
Terry
froggy
(Donor 2026)
x 4
Re: Wishbone
Team WFA.......?
Terry
x 3306
Re: Wishbone
Why F*** About!
x 8365
Re: Wishbone
froggy wrote:Team WFA.......?
Yep, as James says. There's three of us in the team (Chris570, Hydrocobra and I) and we specialise in doing the difficult stuff on Xantias, XMs and other random PSA stuff mainly by hurling large quantities of profanity and big hammers at the job in hand...
Imagine the Top Gear team and you have a good idea of how we are. I'm James May...
We remain undefeated to date. Team WFA 1 Citroen 0.
And we've had some battles and triumphs (as in successes, not the cars)...
froggy
(Donor 2026)
x 4
Re: Wishbone
very good.....keep up the good work !
Terry
x 1999
Re: Wishbone
Unread post by Stickyfinger »
What ??...the gay one ?
x 3306
Re: Wishbone
:sprint:
x 8365
Re: Wishbone
He might be although I don't believe he is as he does appear to have a woman in his life...
I glean that from reading his books...
Northern_Mike
Re: Wishbone
I imagine Chris570 to be Jeremy Clarkson for some reason.
Sent from my SM-N9005 using Tapatalk
Northern_Mike
Re: Wishbone
Nah, he's not. He's been living with his girlfriend for nigh on 15 years now.
x 3306
Re: Wishbone
northern_mike wrote:I imagine Chris570 to be Jeremy Clarkson for some reason.
Nope, because he can use tools other than hammers! I have seen him at work taking apart the engine from an RX8, and working on the suspension of an Activa.
Northern_Mike
Re: Wishbone
I can also use hammers other than tools. I'm much more like Clarkson than may though, and give me a big powerful destructive tool or powerful windy gun any day. I've also done plenty of Activa suspension work..
