Refurbishing spheres
ggbinks
Unread post by ggbinks »
Hi everyone, I'm a newbie to posting so please forgive any basic errors.
I have a 1999 Citroen Xantia SX 1.9TD
Using this site for advice, I've managed to fix numerous leaks, replace water pump, tensioners, auxilliary belts, replace lhm fluid and clean filters etc.Thank you all posters =D>
My problem is that the front 2 strut mounted suspension spheres have gone (I think)
The suspension raises and lowers readily using the lever in the centre console.However, there is no up/down movement when doing the bounce test by pressing down on top of the front wings. It's very firm indeed with no bounce/springiness.
When driving on the highway over undulating sweeping surfaces, the car does feel like a magic carpet ride, it's a real thrill just feeling the car swoop and glide. However, on small bumps, the car seems to have no suspension or shock absorbing qualities at all. So I'm guestimating it's the top mounted front suspension spheres.
Anyone got any practical suggestions for trouble shooting/process of elimination in getting to the bottom of the problem?
Also, I live in Malaysia where new suspension spheres cost 75 pounds each....... :rofl2:
Has anyone ever tried reconditioning a sphere themselves? Vain hopes??
Also, while I'm brain-tapping, the rev-counter works when it is cold, but then after driving for about 15 minutes it gradually stops working????? Does the same thing every morning. I'm guessing it's some electrical connection that expands when hot, losing continuity in the electrical circuit. Anyone experienced this before and got any suggestions please?
Thanks for all your help. I think this site is excellent, and I really appreciate the posters. I've learned so much from you all =D>
1999 Xantia 1.9TD SX 170,000KMs
ggbinks
Re: Refurbishing spheres
PS, I already tried the 10 minute mod, cutting the inlet pipe off at an angle in the lhm tank. Made the ride noticeably softer over sweeping undulations, but didn't soften up the suspension over small bumps and uneven road surfaces. Thanks
x 94
Unread post by citronut »
firstly if there is no movement with the bounce test, you will not get the magic carpet ride,
and it almost certainly will be your spheres have lost there gas,
is there any movement at the rear suspension with the bounce test,
try asking Surjit Singh as he lives in Malaysia also, he has a fleet of various Citroens, im sure he could tell you what he does on the sphere front
here is his email address
*Edited by admin*
Regards, malcolm.
Mandrake
x 695
Unread post by Mandrake »
Probably best to PM that email address then edit it out of your post Malcolm - before the spam bots get their hands on it...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 3296
I wonder how much P&P would be if you ordered spheres from these people;
http://www.aepdirect.com/" onclick="window.open(this.href);return false;
Mandrake
x 695
When I lived in New Zealand I once looked at the possibility of getting GSF to ship over a set of spheres for my Xantia - the per unit cost was much less than the NZ price (as Citroen were the only supplier in NZ) but by the time you added freight it worked out that I had to order at least 6 spheres at once to make it significantly cheaper. Because I didn't need that many spheres I didn't go ahead. For only two spheres the shipping would almost certainly make the total cost more expensive.
Simon
1978 CX 2400
x 8415
Mandrake wrote:Probably best to PM that email address then edit it out of your post Malcolm - before the spam bots get their hands on it...
Indeed. A wise move and generally you should never publish a private email address on any publically accessible forum for safety. Treat an email address like your private telephone numbers.
I've edited it.
Spambots do actively harvest emails addresses accessible on public forums. You should see the crap aimed at the published forum contact address - it keeps my Spam Filters very busy indeed :twisted:
x 94
ok thanks Somon and Jim
will do
pm. sent
Regards, malcolm.
ggbinks
citronut wrote:firstly if there is no movement with the bounce test, you will not get the magic carpet ride,
try asking Surjit Singh as he lives in Malaysia also, he has a fleet of various Citroëns, im sure he could tell you what he does on the sphere front
*Edited by admin*
Thanks, Citronut, back end bounces beautifully, leading me to concur with you about the front spheres having lost their gas.
Thanks for the PM also, I'll email Surjit to see if he knows of any reasonably priced spheres.
Thanks. 8-)
ggbinks
Hell Razor5543 wrote:I wonder how much P&P would be if you ordered spheres from these people;
Just checked out the site, and it's excellent, thanks Hell Razor! The spheres are less than a third of the cost of new spheres here. Great link, thanks. 8-)
ggbinks
Mandrake wrote:When I lived in New Zealand I once looked at the possibility of getting GSF to ship over a set of spheres for my Xantia - the per unit cost was much less than the NZ price (as Citroen were the only supplier in NZ) but by the time you added freight it worked out that I had to order at least 6 spheres at once to make it significantly cheaper. Because I didn't need that many spheres I didn't go ahead. For only two spheres the shipping would almost certainly make the total cost more expensive.
Thanks for that info Mandrake. I think I'd struggle getting them through the customs without getting hit for duty also as Malaysia's quite strict.
Fortunately I have friends visiting from Ireland in December, so I'll be getting some spheres from AEP Direct and getting them shipped to Ireland. My friends can bring them in their cases.
Does anyone know the approximate weight of the front suspension spheres please? None of the sales sites I've looked at has a weight for them. Thank you all 8-)
x 1996
Unread post by Stickyfinger »
Don't know the weight but please let me give you a tip.
Give a set of layout plans, sphere information, fitting procedure and recites to your friend. I have traveled with "unusual" content before and it pays to carry information that even a monkey can understand, eg pictures :)
If you confuse a Customs Officer their brains fuze and they go into default "Bloody Awkward" mode :)
"What's this Sir ?"
Don't really know, a friend asked me to carry it , its a car part I think
"It looks like a bomb Sir "
Really, well maybe yes it does a bit maybe, he (gives address) said its for a French Car...-----Malaysian Anti Terror Squad get called, you get a visit----------
"What are these code numbers and do you know Cuba has good sun at the moment ?"....Sir
:), no really all will be fine if you carry the details of what it is.
x 94
Stickyfinger wrote:Don't know the weight but please let me give you a tip.
"What's this Sir ?"
:yikes: :yikes: :rofl2: :rofl2: :rofl2:
Regards, malcolm.
x 8415
Sticky, I enjoyed that :lol:
I could tell some tales of some unusual stuff I've carried on aircraft in the past.. In more innocent times some 30 years ago...
One was a set of spanners which I still use regularly to this day..
I was asked why I was carrying them..
I replied "In case I need to fix the 'plane on the way home..."
That was considered OK...
Can't imagine it these days though...
electronmirror
x 30
Unread post by electronmirror »
A front suspension sphere weighs 1.67 kg.........I've just put one on the kitchen scales :)
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
