xantia back end collapse
jacksun1987
Unread post by jacksun1987 »
The ground is ok back end not going up not even when I put it on high setting its t reg hdi exclusive
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Have you put the back on stands and checked the "dogbone"? It would be my first suspicion.
jacksun1987
Re: xantia back end collapse
I had a new one put one thus year I think when that happend t went up then slowly went down thus time theres seem to be no movement
Northern_Mike
It's probably broken or come off. Get it on stands and have a look. Anything else is simply guessing.
Sent from my SM-N9005 using Tapatalk
jacksun1987
it was the same thing all sorted now
Xantidote
x 4
Unread post by Xantidote »
Are you saying that you've fitted another new one as the old one had broken like the previous one (in which case why did it break?), or are you saying that the dogbone had just come off the small metal ball on the link to the anti-roll bar (in which case, maybe the steel ball itself has rusted a bit over the years, so that the plastic cup no longer fits tightly over the ball)
Martin
1995 Xantia TDLX (deceased :( )
