F4R - Crankshafts direction of running?
Axa
Unread post by Axa »
Could someone tell me in what direction the crankshaft are running on an F4R engine?
Sent from my LT25i using Tapatalk
2006 C5 1.6 HDi ( vin: VF7**************[VIN obfuscated, can be read by forum staff] )
2008 Grand Espace 2.0Dci Auto
Axa
Re: F4R - Crankshafts direction of running?
Instructions for timeing-belt change says the crankshaft should be turned by hand 2 revolutions clockwise berfor starting the engine. I would guess that indicates the crankshaft are also running in clockwise direction when the engine are running?
Can anyone confirm that?
lexi
x 133
Unread post by lexi »
Yes Axa, that is a trial run in turning the engine by hand.
Honda at one time were about the only engines running anti-clockwise. They did change it at some point recently for conventional clockwise.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Axa
Thanx Lexi! That was the answer i was hoping for!!! :-)
More on the reason i was asking here...
posts http://www.frenchcarforum.co.uk/forum/v ... 15#p424615" onclick="window.open(this.href);return false;
http://www.espace-freunde.net/forum/ind ... msg_num_23" onclick="window.open(this.href);return false;
