Instalation for electric seats on xantia estate from 97.
RibeiroHP
New User
Unread post by RibeiroHP »
Hi.
I recently bought the electric seats from a vsx along with some other stuff...
Came home took the sx+ pack cuir leather seats off... to find out i dont have the electrocal instalation to make them move...
Has someone from here made that instalation by himself that can help me out with a diy?
Or should I just go to a professional car electrician and not wasting time? :|
x 8428
Re: Instalation for electric seats on xantia estate from 97.
Long ago I made some posts about this very subject. A search should find them but basically you need the harnesses to go with the seats if you want the heating to work, and the heating controller rheostats.
The harnesses are stand-alone and easy to remove complete from the donor vehicle.
If you just want them motorable you can get away without the original loom and just connect them to a 40A ignition-switched supply.
I can supply wiring diagrams of the seats if required...
