Saxo clutch cable
Singingdave
- New User
Saxo clutch cable
Hi I am a newbie, I have a 03 saxo and having big problems replacing the clutch cable, the old one broke at the plastic end that hooked on to the pedal so I took the old one off and have been trying to replace it and I'm stumped it don't want to go through to the hole on the bulk head, I can't see it or feel it, I think it'll be easier if I take the engine out. Any ideas guys and girls. Thanks for reading.
- x 94
Re: Saxo clutch cable
hi and welcome
i have never fitted a clutch cable to a Saxo, are you sure you have the correct cable,
Regards, malcolm.
flying clutchman
- x 3
It's easiest to jack the car up and do it from underneath, you can see what you're doing then. Should be a (relatively) straightforward job then. As Malcolm says, check it's the right cable.
