Can anyone tell me the length of the 2 front supply suspension pipes 5270 PR and PP? They're both NFP and Service Citroen doesn't show the lengths
Ta
Xantia front suspension supply pipe lengths
c.morewood
- x 55
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
DickieG
- Monaco's youngest playboy
- x 38
Re: Xantia front suspension supply pipe lengths
I doubt it's recorded anywhere so you might need to run string along the length of the pipes on order to get the measurement, but having said that one place worth trying is Pleiades as they specialise in Citroen hydraulics and will more than likely make up the pipe for you.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 94
probably same or close to the length of a MK1, below are the dimensions for one without hyperactive susp and without anti sink
96 148 510
NFP
HYDRAULIC TUBE
DIAM 6,35 L=1102
96 112 362
NFP
HYDRAULIC TUBE
DIAM 3,5 L=1062
and MK1 without hyperactive and with anti sink, there are two options for each aside rp No. dependent, here is just the one ( for each side ) that is still showing as available
5270 96
HYDRAULIC TUBE
LEFT
DIAM 3,5 L=1020
- BVM BE3 UNTIL RPO 06810
FROM 6902 COEFF 01
LEFT
DIAM 3,5 L=1020
- BVM ML5T SINCE RPO 06902
96 148 510
NFP
HYDRAULIC TUBE
DIAM 6,35 L=1102
96 112 362
NFP
HYDRAULIC TUBE
DIAM 3,5 L=1062
5270 96
HYDRAULIC TUBE
LEFT
DIAM 3,5 L=1020
FROM 6902 COEFF 01
LEFT
DIAM 3,5 L=1020
Regards, malcolm.
c.morewood
- x 55
Thanks Malcolm,
I was only after a rough length ..I doubt I can copy the more intricate routes the original pipe follows.. I thought it might be worth asking as someone on here might know if they're a different length to the Mk1.
DickieG, I need to use Eurocarcare to make them up as they're the only ones, having already asked Pleiades amd M Lockwood, that will combine the C5 suspension upper ends and pipe with the Xantia lower ends.
Thanks for the info,
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
