Vibration on gear shift / Xantia
noxati11
Unread post by noxati11 »
Hello,
I'm here first time, so I hope someone help. My english is not exactly the best level, but I'll try to describe it best. :)
After changing clutch and the gear link rods the shifter starts very unpleasantly vibrate (with sound like metal grinding). It doing only (or mostly?) on 2nd, 4th a and 5th gear in high rpm, about 3000+. Neutral is without vibrate in high rpm.
Replacing the clutch was done in unauthorized service, but with high experience.
Any ideas where could be problem?
Xantia 2.0 16V 112kW 1993.
Xantia V6 Activa
x 5664
Re: Vibration on gear shift / Xantia
Welcome to the forum noxati11 :welc:
Far from being my area of expertise but it sounds like the clutch is slightly off-centre.
Where do you live - not being nosy but this may be an important factor when members offer advice.
noxati11
Thanks for reply. I live in Czech Republic.
Xantia V6 Activa
x 5664
There is a clutch specialist on the forum who will be able to supply a mere definitive answer to your problem - he has seen it all!
Many other members have also had far more experience than I have. Just a matter of waiting until the right ones drop by.
