Xantia Auto Gearbox
ds21h
x 3
Xantia Auto Gearbox
Unread post by ds21h »
Hi I have just acquired a 1999 Xantia V6 with auto box, it is very difficult to get it out of park, does anyone know if there is a sensor or solenoid that allows the lever to move from park?
One it is out of park the lever moves as normal between the other gears.
Mark
Trainman
(Donor 2018)
x 43
Re: Xantia Auto Gearbox
Unread post by Trainman »
I'm Sure CitroJim will be along shortly to answer that
Steve
http://c6owners.org/index.php
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
there is a solinoid on the side of the selector house that is meant to release when the brake pedal is pressed...
However they can and do fail. But, I think you may need to lift the whole centre console up, you can manualy release the solinoid by pulling it while moving the lever. But Im sure its a centre console up, OR just plastic surround that has the gear lettering on it.
My guess is the solinoid has got weak or something. I thought I had a spare from a V6 I broke recently...
A very sad...
1994 XM 2.1 d auto
Mandrake
x 695
Unread post by Mandrake »
There should be an obvious clunk from the solenoid in the centre console when you press the brake pedal with the igntion on and the lever in park.
As its a Series 2 check that the gear lever position repeater on the right hand side of the dashboard actually indicates Park - if not the gear lever switch might be out of adjustment.
It will only operate the solenoid when pressing the brake if it thinks you're in park. I once got stuck where the lever was locked in park but it thought it was half way between park and reverse (flashing red light on the dashboard) and was refusing to operate the release solenoid so I had to manually release the locking pin.
It's actually pretty easy to override the lockout in an emergency - pop up the rectangular shroud around the gear lever with your finger tips (pull on the inside edge gripping the boot slightly) then down the right hand side you'll see a round pin sticking out slightly - it has a groove in it, just use a flat blade screwdriver in the groove to push the pin to the right to release the lock.
I would practice doing this a couple of times and carry a small screwdriver in the glovebox until you get the problem fixed so you don't end up temporarily stranded somewhere like I did!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Stempy
Unread post by Stempy »
Could it simply be a dodgy brake pedal switch?
Lexia ponce
Mandrake
x 695
It could be and I would certainly check that, but if it is then the brake lights won't be working either as they share the exact same contacts...
Simon
1978 CX 2400
