strange noise
froggy
(Donor 2026)
x 4
strange noise
Unread post by froggy »
Hi, while driving my s1 Xantia, Iam hearing a very strange noise coming from the passenger side. The noise sounds like.......long wave radio trying to tune in, then it changes to a tap dancing mouse ! radio is off! heater is off! the " one who must be obeyed" in the house ! the noise happens occasionally , very annoying, any ideas anyone......cheers Terry. :oops:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
dnsey
x 19
Re: strange noise
Unread post by dnsey »
It does sound like instability in some sort of electronic device.
I take it that the radio is still workng OK?
Northern_Mike
Has it got aircon and or climate control? Doesn't the fan circulate slowly even when "off" on these?
Sent from my SM-N9005 using Tapatalk
x 8441
Re:
northern_mike wrote:Has it got aircon and or climate control? Doesn't the fan circulate slowly even when "off" on these?
No, but the fan can make some interesting noises when it is running slowly in 'AUTO' mode. Its speed can vary up and down quite audibly...
I reckon the blower may be a good place to start looking...
froggy
(Donor 2026)
x 4
Re: strange noise
cheers
Terry
xf1ref
x 12
Re: strange noise
Unread post by xf1ref »
I think it could be the little fan from temperature sensor in the dashboard or the stepper motor from the air mixer.
Froggy, also at my car I'm hearing a sound like you describe and is the stepper motor from air mixer flap. I think there are some pinions there and need some grase but I don't know how to dismanlte it.
froggy
(Donor 2026)
x 4
Re: strange noise
thanks
Terry
dnsey
x 19
Re: strange noise
My wierd and probably wrong thinking is that there might be a high-resistance 'something' (insect?) across the radio switch, leaving it slightly on, so to speak.
Mandrake
x 695
Re: strange noise
Unread post by Mandrake »
xf1ref wrote:I think it could be the little fan from temperature sensor in the dashboard or the stepper motor from the air mixer.
The air mixer flap motor does seem like the most likely cause - the clicking could be it reaching the end of its travel prematurely and trying to jump a tooth on the cog...
If you have Lexia access it's possible to manually exercise the mixer flap with the Lexia, which would at least identify the source of the noise.
The tiny fan behind the air vent next to the clock can also make some very strange noises...sometimes you can clean the dust out of the bearing with a blast of compressed air.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
froggy
(Donor 2026)
x 4
Re: strange noise
If I wriggle the electric cables that run from passenger door to car body.......the volume of noise alters. ( the clicking noise gets louder or quieter )
Terry
MikeT
x 232
Re: strange noise
Unread post by MikeT »
Any chance you can get the sound recorded? Your initial description brings to mind the sound of a radio amplifier circuit picking up a mobile phone's handshake to a cell tower.
" onclick="window.open(this.href);return false;
