My daughters '99 1.4 8v Saxo sx automatic is playing up.
She brought the car back to me about a month ago now because the engine for some strange reason it just dies. The car would then re start ok until it would cut out again, this has happened to me 3 times in the first few days of me having the car back.
The car was runnning like this for four days starting first turn of the key and without any throttle and was correct amount of fast idle. Then one day it went mad reving up to 2,500 rpm all on its own, even once the revs had calmed down a bit the engine still carried on cutting out.
The coil pack was the original one so I renewed with a brand new one, I also renewed the crank sensor ( which was renewed 4k miles ago ) anyway. I have also renewed the idle air valve with a brand new one and I have carried out an electronic reset of the tps twice now.
At the moment the car will not start unless I give it half a throttle pedal of throttle and won,t even run right, the engine seems to be hunting quite alot. The only thing that makes the engine to start and run any better is if I undo the jubilee clip that holds the air filter assembly on and pull it away from the throttle body to create a gap.
I have found that the air filter element is a quite grubby so I removed it out of the equasion and the engine is back to not starting again without lots of throttle bieng applied.
The engine revs over 2, 500 rpm nicely and sounds pretty good and definately no repeats of the head gasket problems that were sorted out 4k miles ago either
I will be trying a new fuel fiter next in a hope to the car running properly again.
Any help or advice would be very very gratefully received
Many Thanks Indeed,
Vince.
