Xantia Headlight Bulb Recommendations?
x 8363
I need a new set of headlamp bulbs for my V6 as one dipped beam bulb has failed.
What's the current highly recommended bulb to get and from where?
Thanks :-D
x 1485
Re: Xantia Headlight Bulb Recommendations?
http://www.powerbulbs.com" onclick="window.open(this.href);return false;
Pretty sure I've got a 10% discount code somewhere :)
I've used the Osram Nightbreakers to good effect - I see they're now 'Nightbreaker Unlimited' - coupled with the relay mod of course.....! Not that long lived, but better that than putting it in the ditch.
SaabC5
Unread post by SaabC5 »
Always had good results from Osram Silverstars as well.
x 8363
Thanks both :-D I will be getting a set for stock but I find I didn't in fact have a blow bulb..
It was all down to a bit of bad workmanship :oops: I'd removed that headlamp to improve access to the HP pump when I resealed it and completely missed the fact that headlamps work much better when they're actually connected to the wiring loom..
I plugged the headlamp in just now and all is now happy!
x 1485
:-D =D>
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
as much as i dislike suggesting them, Halfords have a B.O.G.O.F. on its own bulbs at the mo for the brilliance / super brilliance/ and other ranges, they also had a deal on upgrade bulbs at a fiver each, pickd up a pair when mine went on one side, otherwise, the osrams as mentioned, very good!
'58 C2 Code
'58 partner teepee outdoor
