fuses heater plugs
john the hat
fuses heater plugs
Hi i have a 2003 picasso hdi that wont start there is a fues box next to the ecu for heater plugs with 3 fuses 2 relays i have mixed them up as onely 2 are used but i don't know which 2.they are for heater plugs. Can anyone help.
- x 1498
Re: fuses heater plugs
Hi John - welcome!
I very much doubt that the heater plugs would stop an HDi starting - the fault is almost certainly elsewhere. However, not sure about the relays you mention - one of those could be causing the problem. If it suddenly decided it wasn't going to start it could be the in tank fuel pump (if it's got one!).
