Hi people, I hope u can help me, I have a 306 xsi s reg. for just over a week my car seems to be misfiring when I try to rev it. But if you keep the revs up its fine. Also does this low revs when driving, After this it seems to pull well. I've also noticed when starting it will fire up as normal ( meaning a couple of turns and it fires) but it seems like it doesn't reach idle smoothly. Hope this makes sense
Not 100% it's missing or whether it's just spluttering bcoz it's fuel related
I've changed the plugs so far and was going to change the coil pack next but thought I would ask on here first. Thanks for any advice
Electrics or fuel????
- x 1240
Re: Electrics or fuel????
Mmm, haven't run a petrol car for about 30 years they didn't have coil packs then but your fault sounds typically weak spark or weak mixture so coil packs could be the problem. Presumably it has fuel injection, a weak mixture will give the same symptoms. Does it only do it when cold or all the time?
Willow1983
Hi, thanks for reply. It does it all the time, I've unplugged each injector at a time and it has made the car run different so I guess the injectors are ok. Would this also mean it's sparking ok?? Someone mentioned at work could it be the head gasket? It doesn't use oil and I've topped the water up once in the last 6 months. No signs on oil or water cap.
addo
- Sara Watson's Stalker
- x 95
Willow1983
Ok will try and check as much as I can tomorrow and take it to the garage for the pump, had it plugged into a computer Saturday and there was no codes showin up. I hate electric said of cars. Thanks for reply
isisalar
- x 3
When was the cambelt last changed? Check this out
http://www.frenchcarforum.co.uk/forum/v ... =3&t=49076" onclick="window.open(this.href);return false;
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
