Not sure what this is?
xantiagreen
Unread post by xantiagreen »
Engine bay passenger side directly under windscreen scuttle not sure what this spongy sort of papery thing is arrow marked 1 is the drain hole to the top of it is the vent for the heating (I think) and arrows 2 is the unidentified item.
I was removing all the crap mostly leaves using a coat hanger to coax them into the drain hole and push them through I sort of ripped the papery thing, so I'm worried some things going to fail is this replaceable. Image
Also when tyres were being changed I noticed arrows marked 1, is this ok and what did it do before it was cut, can I or should I re-join the 2 wires?
Cheers.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
x 8358
Re: Not sure what this is?
The first is maybe sound deadening and the second is the wiring to the brake pad wear sensors.
I'd look more closely at the sound deadening as you don't want it becoming saturated with water. Best to remove it or repair it...
xantiagreen
CitroJim wrote:The first is maybe sound deadening and the second is the wiring to the brake pad wear sensors.
Why would you cut the brake pad sensor wire, would it be easier and cheaper to fit another one or just mend the existing, should there be one on the other side too?
If it's sound deadening it's only in that small area boxed in and on the other side is just metal no sign of opening. Seems a weird place to put a small piece of it, will have to get the hair drier to it.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
x 3304
I wonder if the wiring just failed through age (and, possibly, having the guide grommet moved too far, causing excessive loading on the wiring). There would be wiring on both sides, and the way it works is that there is a metal contact within each pad. When the pad wears down enough that contact touched the brake disk, closing a simple circuit to earth, and the relevant system would then 'know' the pad has hit its' limit, and needs to be replaced. It might be possible to replace that damaged wiring, and (if possible) bringing that system back into life.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Yes they dont get cut.. they break up.. the wear sensor wire is less flexible then abs sensor cable..
so it breaks..
A very sad...
1994 XM 2.1 d auto
xantiagreen
citroenxm wrote:Yes they dont get cut.. they break up.. the wear sensor wire is less flexible then abs sensor cable..
so it breaks..
Have just had a look online cannot find anywhere that does Brake wear sensor cable, tried euro/micks garage/ebay/ nothing
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
superloopy wrote:
so it breaks..
Cheers
Buy a new set of pads ... they'll be in there. Save the pads for future use.[/quote]
Will that be the whole cable that I need whats been cut in photo.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
x 3304
Oh well, get out the soldering iron, 6 inches dual core cable per side, and the heat sleeving. With care you can get it working again. The wires that come with the pads are to link into the loom. If you look lower down in the second photo, you can see the pad wires just above and behind the hand brake cable (two pale wires).
citroenxm
Fallen Hero
x 70
superloopy wrote:
so it breaks..
Cheers
Buying a set of pads WILL NOT get you the car loom!!
That broken wire there will need soldering up, as James says, if you are handy with an iorn that is, shouldnt be that hard to solder up..
A very sad...
1994 XM 2.1 d auto
