the car is an 03 206CC 1.6 16V 110 TU5JP4
the owner says if/when using the indicators they come on then of and the head lights come on in there place,
she has been told it will probably cost over £400 squid from the local pug dealer, and i dont think they have plugged there analyser in yet, as they quoted her £50 squid to do so,
funny as my new neighbor has just bought an 02 Xsara Picassooooo which has more or less the same symptoms
03 206CC lighting fault
- x 94
Regards, malcolm.
- x 5577
Re: 03 206CC lighting fault
Sounds like the dreaded comm2000 disease Malcolm.
- x 94
i have read on tinternet it is possible to dismantle the COMM 2000 unit, clean, lub and re/assemble, has anyone on here done this successfully?????
Regards, malcolm.
Northern_Mike
No but the guy on Bradford who repairs them has good things said about him on the Berlingo forum..
I think you can do it, but you need to drill out the plastic rivets or something.
If you stick planet or Lexia on them Malcolm, it'll report comm 2000 faults. If it doesn't report any, it's probably steering column earthing or loose connections causing it to go screwy.
Sent from my SM-N9005 using Tapatalk
Gibbo_Wirral
Yep, the guy in Bradford is a Peugeot forum regular, and a great guy to boot. I've used him a couple of times.
This is his listing:
http://www.ebay.co.uk/itm/COMM-2000-PEU ... 27ea2140c1" onclick="window.open(this.href);return false;
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
- x 94
just did a goooogly search on how to dismantle a COMM 2000,
and this is one result that came up for fixing a floppy stalk ( NOT )
Regards, malcolm.
