Mystery coolant leak - Solved?
Old-Guy
x 24
Unread post by Old-Guy »
For some long time, the Green Lady has had a slight thirst for coolant; not enough to worry about, just irritating that every few hundred miles she needs a small top-up. No drips anywhere visible and it seemed to get better after I changed the thermostat a couple of months ago - leaky old seal?
Too simple, the thirst returned with the next long fast trip.
Then when looking for simple causes of the spluttery 'cold' starts, I spotted a drop (just one) of coolant way below the bleed cap behind the injector pump. Further investigation revealed that the Schrader-type cap had a slight split - swopped it with a new valve cap off one wheel.
The original blue cap escaped down the back of the Bosch pump several years ago and was replaced with a spare tyre valve cap of unknown age.
I suspect that when the engine was really hot, the split opened up under pressure releasing a tiny fine spray of steam. Changing the thermostat improved matters because the cooling system could cope better with hard driving and the engine now rarely goes above 83°C - full power up big hills (Haldon Hill A38 south of Exeter and Wells Hill on A37).
So, if your XUD engine starts to use a little coolant, check the bleed cap (or just fit a new one!) before looking for anything more serious.
DickieG
Monaco's youngest playboy
x 38
Re: Mystery coolant leak - Solved?
Unread post by DickieG »
Coolant bleed caps are different from tyre valve caps as they have a small rubber o-ring gasket at the bottom so best to stick to the correct cap as after all they can't cost very much new from a dealer.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 5671
They are about 30p IIRC and the plastic ones have been replaced with metal ones.
x 8353
Good work Guy :-D
Those are really hard to locate I know...
Old-Guy
x 24
myglaren wrote:They are about 30p IIRC and the plastic ones have been replaced with metal ones.
Plus the 20 mile round trip to get one! However, I have to go to Gloucester anyway on Friday...
