306 XSi intermittent speedo
franster
Unread post by franster »
Basically the speedo on my 306 XSi only works when it feels like it. I had thought it may be the speed sensor, but when I was sitting in traffic the other day, the needle began to hover at around 10mph even though the car was not moving. I'm now more prone to think it might be a faulty speedo, but would like a bit of advice before I start guessing and buying parts I might not need.
Thanks in advance
2000 306 XSi 3 door
1997 ZX 1.9 TD SX 5 door
2004 Alfa 147 2.0 Lusso (Mrs F's)
x 1240
Re: 306 XSi intermittent speedo
Unread post by Peter.N. »
Could be a bad connection on the sensor plug, any varying resistance can be interpreted by the speedo as pulses. Is the mileometer working, if yes then it probably will be the instrument but if not more likely a signal path problem.
franster
Mileometer only works when speedo does, which is why I initially thought it was the speed sensor. I'll try and trace the wires and clean up connections as a first point of call.
Is the speed sensor on the back of the gearbox, near the driveshaft output?
2000 306 XSi 3 door
x 94
Unread post by citronut »
franster wrote: Is the speed sensor on the back of the gearbox, near the driveshaft output?
yes the transducer fits were a speedo cable would normally plug into the diff casing just above the O/S drive shaft outlet,
and the wiring connector plugs straight onto the top of that
Regards, malcolm.
franster
Checked and cleaned the connections on the speed sensor and refitted. Still the same!
Any more ideas? Would the sensor itself work intermittently, and give false signals at standstill? Do I need to be tracing wires looking for frayed bits shorting to earth? Should I just leave it and put up with it? AAAARRRRGHH!
2000 306 XSi 3 door
x 94
yes it is possible,
i have seen a transducer full of gear oil as the spindle O ring had failed, i took it apart cleaned it out and refitted it, then it worked fine fa quite a few thousand miles, the car went to meet its maker before i saw the cleaned transducer fail again
Regards, malcolm.
franster
citronut wrote:
yes it is possible,
Thanks. I'll give that a go.
2000 306 XSi 3 door
