Windscreen washers
Timmo
(Donor 2022)
x 168
Re: Windscreen washers
Unread post by Timmo »
my pump failed on me recently, absolutely fine no problems, then next time went to use it, nothing!
£3 from local breakers, -same as pretty much all the front and rear wash wipe 306/xsara's/206's
'58 C2 Code
'58 partner teepee outdoor
Timmo
(Donor 2022)
x 168
Yup, unplug the wire plug on top, pop the two pipes off and pull it out, put the replacement in, If youve refilled your washer fluid to have a bucket/container to catch it all in! ;-)
If your local yard allows you to look around still is handy as its a practice run! And you can Pull the arch liners out the way without Worrying about putting it back! :-D
'58 C2 Code
Timmo
(Donor 2022)
x 168
:-D fortunately mine has over winter for mot work and was only cabletied back in place! ;-)
'58 C2 Code
