Xantia heater blower
wallerr
My 1996 Xantia TD 1.9 heater blower works unless temperature outside is freezing. Frustrating as this when you need it most. Any ideas?
AndersDK
Michael P
David Goddard
thomas
JonR
I also had trouble with Xantia heater fan, it would run when it felt like it, sometimes at full speed and sometimes slow and sometimes not at all. I had read forum so suspected ignition switch, or speed control unit. However both of these OK, so eventually got to fan motor on passenger side. Took it apart and found that brushes in motor were well worn and jamming in holders, cleaned them out, a spray of WD40 on all parts, then reassembled, motor running at full speed again. This is a DIY job, took me altogether about an hour, 3 screws to remove carpet, 3 screws to release unit, and then the complete motor and fan are a push fit in the housing so straight forward to complete, now have a nice warm car again instead of a mobile fridge. JonR
