hi.
I own a 2007 Peugeot 206 with AL4 Gear and TU5JP4 engine.
I have two questions:
1) I need to replace the engine mount but the genuine one is very expensive, and I want to replace the 65MM bus, I heard the the SASIC 8003201 will be pretty good for me but I don't know the correct installation of the bush because it alitle different from the genuine one (added a picture)
2)my AL4 transmission have an issue, the changing from 3rd to 4th gear is kicking very hard and usually kick in within 2200-2500RPM which cause a 5 second of lag until the RPM reach higher, second thing is the 2nd gear has a delay and RPM drop for 2 seconds (causing the feeling that he changed the gear but is not) its also happens in TIPTRONIC mode, when I am in the second there is still a feeling of gear change.
I did an oil replacement and the two valves replacement.
any ideas plz?
best regards!!
peugeot 206, need help with engine mount and AL4 issues
gabi911
- New User
gabi911
- New User
Re: peugeot 206, need help with engine mount and AL4 issues
there is a link to the picture mentioned above:
- x 94
if you do not have the OE part No. and you send me the last 8 digits of your chassis/VIN No. i will get it for you, then you can do a google search to see if you can find someone selling NOS = new old stock,
although if its the same size bush as on the likes of BX's and Xantias then GSF sell just the bush i think for around £8 or there abouts
Regards, malcolm.
