Suggestions to clean the side bumpers on Xantia.
ihatecars
Unread post by ihatecars »
Any suggestions for cleaning and making look great those grey plastic side protectors (halfway up the side of the car about 2" tall) that run down either side ofa Xantia? I have tried some Plastic Trim Cleaner from Halfords which takes an age to apply, I just need something quicker.
I notice the side protectors have a fine lumpy texture to them which seems to hold the dirt. So mine at the mo look a little grey and weatherd but know with the right cleaner would look, well hopefully almost new
Any suggestiond for cleaning??
x 3306
Re: Suggestions to clean the side bumpers on Xantia.
I would use a toothbrush on them, so that you can get your cleaner into those gaps.
RobinMasters
Unread post by RobinMasters »
They're probably faded rather than dirty. Either rub something oily into them (linseed oil, peanut butter, old engine oil), or gently heat them up.
Old-Guy
x 24
Unread post by Old-Guy »
Oily substances (and that includes Back-to-Black) don't last, attract dirt and make cleaning harder.
The way s/h dealers make grey unpainted plastic external trim look black again is to heat them with a hot air gun - at the same time even quite big dents can be (largely) removed:
First thoroughly clean the plastic with detergent and a softish brush.
Then very carefully heat with a hot air gun on low heat. Keep the gun moving all the time and keep the hot air off all paint-work; use a corrugated cardboard shield held in the other hand when necessary. Do not touch the hot plastic with anything! Experiment on a hidden area first. The plastic will turn black again just below melting point - the trick is to get the surface of the plastic soft without the heat penetrating too deep.
Removing dents requires care and percy-whatsit - then all you have to do is heat-treat all the rest of the trim to restore it all to a uniform and original black :-D
ihatecars
wow thanks boys, esp, Old-Guy for giving full instructions because I saw the heat gun trick on YouTube but wasn't sure if it was genuine knowing the opportunity for disaster is high. Now you've confirmed it, next time I'll give it a go, in the meantime I backed out and did the oil trick.
harryp
(Donor 2022)
x 73
Unread post by harryp »
Old guy, does this work on red and silver and bumpers too - but I don't want them turning black :?
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
