Err, front height adjuster plumbing
mardybum
Unread post by mardybum »
Ordered some new pipe for a mates xantia after a massive fluid loss.
It doesn't look like either of them have the restrictor rod in, and the others are far past I to tell which was which to be honest.
Does anyone know the answer to my riddle?
Steve
handyman
Re: Err, front height adjuster plumbing
Unread post by handyman »
I'd look at the LHM pump return pipe first as thats always a good source of leaks.
H
x 8353
Steve, do you mean the thin steel wire inside the pipe? If so then that one is on the functional return side of the height corrector. I believe it's there to prevent the return lines back to the LHM reservoir being overwhelmed with LHM in case of large and sudden height corrections...
mardybum
Definitely the pipes coming from the front height adjuster, I think its the feed pipe, with it being under extreme pressure, that's given up.
It seems the replacement does have the rod inside so all is well. Thanks for the speedy response.
Side note though..Any tips for removing oil/lhm stains from tarmac and concrete?
x 3304
LHM usually comes away with plain washing up liquid. You might want to try an orange based cleaner on the oil, but no promises on that.
mardybum
Excellent, cheers Hell Razor! Will see what the Mrs has got in the cupboard..
x 8353
LHM stains fade quite quickly on their own but James has the right idea. Washing powder also works...
Northern_Mike
When I was an apprentice at a Citroën main dealer we cleaned up LHM with car shampoo and water.
Sent from my SM-N9005 using Tapatalk
mardybum
Apart from rising and sinking faster than before, this one is sorted too. Been on a roll tonight, even managed an oil change on the Mrs' Passat.
Never had so much done in less than 3 hours!
x 8353
Excellent!
