C5 suspension pump faults
x 5688
Seems to be a common problem so here are some links to threads covering testing and repair options.
Pauls Pump Replacement Thread
Thread 1
Thread 2
Thread 3
Thread 4
Thread 5
Thread 6
Thread 7
x 5688
Re: C5 suspension pump faults
Just spotted this on YouTube:
x 2938
I think he made more work of that than necessary Marc, I've never had to move the bumper or headlamp and in the first few frames draining the tank can be done by disconnecting the hose at the bottom join into a bowl instead of having to keep using empty LDS pots and having an elbow full.
x 6950
Not guilty Gibbo - It was Steve who posted that - useful, but a bit of a bloody mess!
EDC5
x 130
Unread post by EDC5 »
I also repaired the suspension pump on my C5. Some of the pics might be useful.
viewtopic.php?f=22&t=60565&p=581404#p581404
x 2938
GiveMeABreak wrote: 23 Nov 2018, 18:46 Not guilty Gibbo - It was Steve who posted that - useful, but a bit of a bloody mess!
Sorry Marc, no good being stupid if you don't show it. :oops:
x 5688
C5 suspension pump dissasembly.
x 3298
EDC5 wrote: 24 Nov 2018, 01:05 I also repaired the suspension pump on my C5. Some of the pics might be useful.
I found your blog. Can you tell me where you got the replacement brushes from (that you said you did)? Thanks.
x 5688
viewtopic.php?p=423599#p423599
Jovani wrote: 08 Oct 2014, 08:10 Here's our photo report on the repair of the hydraulic pump. I apologize in advance for bad English - for faster translation we use Google Tanslate
Raise the vehicle on a max. position, jacking, removing the right wheel and the front of the fender. Leaning car pivot holder and placed in the lowest position REQUIRED!!!. Deprsharize using LEXIA or other means to loosen the air vent on the right WING INNER FRAME.In the end, disconnect the battery.
To remove the tank, top detaches Reversed top, underneath the fender from the tire return hose and drain into a clean container / tube oil
Lift tank and it is another disconnected Reversed and suction hose
Once removed tank, detachable Reversed pump and the coupling of the electronic block
Continuing with disconnecting the suction hose from the pump to the suspension and from the pump to the rudder servo
Following two tubes of high pressure to the front and rear axles. Particular attention to the two green "O" ring - one fell, but found it. Without them there is no seal then.
After unscrewing the nuts on the rear pads and disconnecting the motor cables take out dead pump. Unscrewed from the pump to the hydraulic unit is removed the back cover, remove the wiper shaft is furnished and management, pull gently pump, store counter of the box and develop rotor box - with a reverse thread.
It totally disassembling and cleaning. At the front end of the pump shaft has a nut underneath circlip - is removed. Camp hood is kapselovan but munched - change for pennies. Back is a bronze bushing - after washing lubricated.
And that is the culprit for problems.
Because things smack ...
we decided to see what was in the control unit of the engine, but the bastards have it covered with black paint, though in good will could get our hands on the marking of transistors
After a wash, it is as ever wash all offal motor
We changed the front bearing, rotor went fine grinding and balancing
Assemble in reverse pump smeared with black silicone management (factory was also smeared) and assemble the car
Pour oil and now attention - to be swell tank with over 0.5 atm. pressure to be able to lift the pump. Quite straining fell :) dry after repair pump is not heard, and quite disturbing. Is less citroaerobik (up and down) and move the car in the shade cleaning mistakes and train his brain
In the end a video
