I thought it best to start a new thread as an update to my previous thread here
http://www.frenchcarforum.co.uk/forum/v ... =3&t=49313" onclick="window.open(this.href);return false;
As I am now having a different issue! :-/
So I managed to update the firmware to 8.31 and tried to instal my new maps again. This time the procedure seemed to go ok until the final reboot. It rebooted, ejected the cd then had the message 'checking hdd', followed by 'performing system maintenance'. Then it took the cd back in, said "identifying cd" then asked if I wanted to update the maps. To which I answered yes, then it proceeded to install the maps again, followed by the same sequence as above!
This just goes on in an endless loop! I have tried taking the cd out when it ejects but then when I try to put an address in the search it asks for the disk.
I have tried selecting 'no' when asked if I want to update, but then there are still no maps.
I have even let it carry on this loop several times but it just carries on unless I interrupt it at some point by saying no!
It seems whatever I try, I still have no maps available even though the install process seems to go ok (although maybe it doesn't because it just goes around in the loop stated above!).
I'm not sure if it's relevant, but when I look at the 'map database list' the new maps are on the list, just not available to use it seems!
I even downloaded new maps from gps underground to try, but exactly the same thing happens.
Can someone please offer an help as I am pulling my hair out!!!!
Maps not working on RT4 navidrive, install issue?
klick307
Re: Maps not working on RT4 navidrive, install issue?
Hi Lynswin,
Have you solved your problem?
I've the same issue, i've formated the maps partition with mirascripts and then reinstalled the 8.31 firmware and all the 2014/15 maps. It still the same.
Any ideas
Best Regards
Any ideas
Best Regards
DickieG
- Monaco's youngest playboy
- x 38
When the cd ejects if you leave it in the slot the head unit will take the disc back in a never ending cycle, if however when it ejects you remove the disc job done, well it was for me.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Trainman
- (Donor 2018)
- x 43
Are the disc genuine Navtec or copies? DockinG is correct though, I've updated a C6 today with out any issues.....
Steve
http://c6owners.org/index.php
Fedupofc5
Just to give an update, i have tried pressing the 'dark' button for ten seconds and its still the same.
klick307
Hi everyone,
I've managed to solve my problem.
After Format the maps partition with mirascripts i've reinstaled all maps again.
The big trick is:
The 1st map needs to be FRANCE, the rest of the maps have no order.
BR
The big trick is:
BR
