Hi guys. Noticed today when I turned the engine off after a drive that the brake pedal pulsed for 10 secs. Something to worry about?
I do still have a lhm leak from or near the doseur brake valve. Have got a endoscope camera (yay!) but it's still too hot to be working on the car unless I really have to...
Thanks!
Pulsing brake pedal when turning engine off
Jaf
- x 42
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
Mandrake
- x 695
Re: Pulsing brake pedal when turning engine off
Does it always do this brake pedal pulsing when turned off ?
Try removing the ABS fuse then repeating the test. That will at least narrow down whether its an ABS related fault...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Jaf
- x 42
Thanks but she doesn't have abs. Too fancy for Fred. The pulsing happened again today when I tested it. I wouldn't normally have my foot on the brake pedal when turning the engine off, perhaps I should stop doing that!
Brakes are working fine and pads have only done 10,000kms.
Hopefully it's just the lhm just being pumped back to the tank as because she is LHD the doseur valve is right underneath the tank.
Mandrake
- x 695
If you have no ABS then how good is the condition of the accumulator sphere ?
Simon
1978 CX 2400
1978 CX 2400
