citroen c6 hdi 2.7 coolant leak
ststech
Unread post by ststech »
i have just bought a 2008 c6 2.7 hdi
it has suddenly developed a bad coolant leak coming from underneath the rats maze on top of the block in center
as fast as you put coolant in it pours out i think and recall seeing a post about a water manifold damaged in this area
can anyone shed any light on the subject
thanks Simon
2007 Citroen C4 grand picasso 2.0 hdi egs exclusive silver
1993 Citroen bx tzd estate silver
2008 Citroen C6 2.7hdi exclusive storm grey
hattershaun
(Donor 2022)
x 4
Re: citroen c6 hdi 2.7 coolant leak
Unread post by hattershaun »
Hi Simon,
You may want to ask the same question on the http://www.C6owners.org" onclick="window.open(this.href);return false; forum.
There are some very knowledgeable people there.
I have heard of the plastic thermostat housing failing & I think it's located high up, on the side of the engine block.
Best of luck fixing it.
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
