As for now, service.citroen.com is not accessible from this part of the world, I need help from someone who have access to find the correct part numbers for the following parts :
Idle control valve,
MAP sensor
Fuel Pressure regulator.
My car is 1995 Xantia 2.0i 8v.
VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
Many many thanks.
Cheers,
Elan
Need help with part numbers
elvito
1995 Citroen Xantia 2.0i 8V
- x 94
Re: Need help with part numbers
it seems to me service citroen will not accept just the last 8 digits of the VIN No. at the moment
this is the second time it has not recognised a car by the last 8, then entering to full VIN it see's your car
i think these are the part No.'s you require
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00001920N1 IDLE REGULATOR MOTOR 111.11 GBP 133.33 GBP 133.33 GBP
00001920P2 INTAKE AIR PRESSURE SENSOR 73.42 GBP 88.10 GBP 88.10 GBP
0000198508 INJECTION REGULATOR 65.38 GBP 78.46 GBP 78.46 GBP
Regards, malcolm.
- x 94
just tried ot again and it comes back with
"VIN CONTAINS ONE OR MORE SPACES"
Regards, malcolm.
elvito
Thanks for the part's numbers Malcolm.
From here, Thailand, I can not even register to service.citroen.com. The register button is not available. I can see the register button if I use proxy but it doesn't work.
I used to be able to log in and register.
- x 94
Regards, malcolm.
addo
- Sara Watson's Stalker
- x 95
