Hi guys,
I've got the 406 hdi 110 as a few of you may know. Recently the car has been doing this strange this where it seems the car cuts out for a split second and then its fine again, while driving you can feel a real jerk when this happens.
also yesterday the engine just stopped when i went to change from 1st to reverse, i still had the clutch down so I'm sure I didn't stall it!
This morning I put PP2000 onto the car and im getting a engine ecu fault code "intermittent fault. engine speed. coherence"
I'm not sure what this means but I'm thinking maybe a crank shaft sensor? or cam shaft sensor?
Cheers for any help
Patrick
406 hdi 110 engine speed fault code
- x 1496
Re: 406 hdi 110 engine speed fault code
Crank sensor I expect - I think the cam sensor is only used at start up to confirm that cam is rotating and in synch with crank.
patrickgledhill
Cheers Richard, I think i might have a go at changing that out. Do they get dirty?
I'm assuming the the sensor is located down buy the crankshaft pulley?
Cheers
Cheers
- x 1496
They're not really known for giving trouble - it's on top of the gearbox, bit difficult to access AFAIK as it's buried under a load of wiring.
