Oil change
KennyW
x 165
Oil change
Unread post by KennyW »
Good morning everybody,
Interesting observation.
I've just done my regular oil change but replaced 10/40 oil semi synthetic with 05/30 w oil fully synthetic and the rattling tappets I had, have gone :!:
It was always about 2000 -3000 rpm.
Kenny
C3 1.4 petrol (SWMBO)
x 1240
Re: Oil change
Unread post by Peter.N. »
Never had a problem with them on an Hdi but the 2.1 XMs used to clatter after I had done an oil change and then get quieter with mileage.
Timmo
(Donor 2022)
x 168
Re: Oil change
Unread post by Timmo »
If i am correct, the lower the numbers the thicker the oil?? So intheory the newer oil should help silence the little rattles??
I remember putting in ep75 in my old gti box as the synchro was showing signs 4th - 3rd when hot,sorted it but cold mornings were. Interesting for the first few miles! ;-)
'58 C2 Code
'58 partner teepee outdoor
x 1498
Re: Oil change
Nope, other way around - lower numbers = thinnner. The first number is the equivalent straight grade it won't go thicker than when it's cold, and the second the grade it wont go thinner than when it's hot.
Timmo
(Donor 2022)
x 168
Re: Oil change
Hmmmn, where did I install the lower is thicker from then I wonder??
'58 C2 Code
x 5679
Re: Oil change
Timmo wrote:Hmmmn, where did I install the lower is thicker from then I wonder??
You’re thinking of IQ :twisted:
Timmo
(Donor 2022)
x 168
Re: Oil change
:-D
'58 C2 Code
x 1240
Re: Oil change
:-D :-D
